Dmarks
- Jan 9, 2014
I have brought my sled out twice within the last month to clean up and get ready for the summer. Twice now when I go to restarts the sled after a couple of min (2-4) it goes on a prolonged crank and will not start so I stop cranking after 10 sec. Next time it takes a bit then starts up. Never happened over the winter could this be due to the warm weather? Bad gas? Anyone else had this problem? Or am I just worrying about this too much? Thanks oh sled is 2015 no codes come up also. Oh one last thing, is there a flash coming out this year thought I heard something about it
My guess is fuel in the lines and rail goes bad. No word on flash yet.
Joe ltx-le
- Mar 26, 2015
- Beaverbank-ns
- 2017 sidewinder ltx-dx
This happend to me last year. It seemed to fowl up.
Best bet is to try not to start and stop it a lot during the off season.
TestMaster
- Sep 28, 2013
- Alba, Michigan
- www.gdls.com
- 2014 SR Viper LTX SE
2014 SR Viper LTX DX
2001 Venture 600
Given to a friend - 1998 SRX 700s
If you don't let the sled warm up completely before shutting down you will load up the plugs. I would recommend at least 165 degrees but 195 degrees or the radiator fan kicking in will not hurt a thing.
Also think about putting a charger on your battery at least once during the summer I use an OptiMate 4 charger by TecMate, a OptiMate 1 for maintenance only, and an OptiMate 6 for larger batteries, they are automatic battery tester, desulfator, chargers, and maintainers. With 3 snowmobiles, a golf cart, a side x side, and diesel mower I just don't want to play with battery no start issues. Using these chargers I never have starting problems nor do I ever replace batteries, well OK seldom. In 2013 I finally replaced the second battery in my 2001 Venture. but it sat unused or unmaintained from 2005-2008 when I was working in Florida.
cobrajet ltx dx
My 15ltx does the same thing in the off season, i notice it more above 50 degrees. During the winter month's it starts fine. 3200 miles and counting.
Cfpdscott
- Feb 23, 2016
- Illinois
- 2016 Yamaha viper Rtx-se
X2 on the optimateIf you don't let the sled warm up completely before shutting down you will load up the plugs. I would recommend at least 165 degrees but 195 degrees or the radiator fan kicking in will not hurt a thing.
RTX
- Mar 31, 2005
- massachusetts / maine
- 2014 viper rtx
2006 apex rtx
Mine always started screwy. Cold starts, hot starts, no consistency.
I just did the evo reflash last month. I can honestly say the sled starts better now than it ever has.
Absolutely no issues starting anymore
