Hartman tunnel extension and rear cooler mounting
AttakMax
Corner Brook, NL, Canada
Canada
2013 Nytro XTX 1.75 Supercharged
2007 Attak 144" ZX2
2002 SRX 136" Mono
I am in the process of installing a Hartman tunnel extension in my 07 Attak to stretch it to 144". This is to accomodate a new 144" ZX2 suspension and 1.5" Crossover track. My question is can you still use the stock rear heat exchanger with this tunnel extension. The new extension sits alot higher and follows the lines of the rear tunnel section which leaves the exchanger on a different angle. I am wondering if I will have to get another exchanger. Thanks.
Someone must have went through this already?
