Frostbite
Here I am looking through the Mountain Performance catalog and I see their version of the Bender stage 2 turbo. I see it's more expensive than the standard stage 2 also because its:
1. 16 lbs. lighter than the stage 2 system.
2. 100% titanium exhaust system.
3. Titanium mounting plate for the turbo assembly
4. An aluminum charge tube
5. Self contained oil system integrated into the sleds dry sump oil system.
6. lighter front intercooler
7. lighter fuel supply system
Bottom line is it retails for about $800 more than the stage 2 system. Do you think the above items make it a worthwhile upgrade for someone considering a turbo? Powder Blue
16lbs for $800 is $50/lb not to bad for weight loss, but when you figure that is above the cost of the stage 2 which is $600 more than the stage 1 then NO I don't hink it is worth it. That's $1400 more total.
Nut Sack
I'll tell you what's not worth it: sitting out the season *wondering* if the kit is ever going to show up. I ordered one (with deposit!) months ago, and still no one can tell me whether or not it's going to show up in the forseeable future.
Otherwise, I'd say Yeah-- If you've got the dough to blow, save the weight! (Assuming you're a mountain rider...)
ExTrEeMF7
BUY A JEFF SIMONS CPR TURBO from matt or jeff
www.thespeedshop1.com
or go to http://www.simonscpr.com
hell hes turbo is 4500us with a money back garenty ....
why buy somthing that guys dont garenty you money back .
i just dont understand some you guys way of thinking ... :shock:
nobody elss is offering a money back garenty :?: . so that must mean somthing :idea: . JEFF is backing hes turbo up 110% and you all know he will be there to help you with it..
POWERHAULIC
14 1/2 years old ^
Buckeye
- Lakes Region, NH
Bender Post??
Wasn't this post about a Bender Turbo? :?:
POWERHAULIC
Sure was Buckeye, somtimes hijackers come along tho :lol:
I considered the lighter version, but decided not to spend the money, just turn up the boost 8)
ExTrEeMF7
cry me a river mxz900
MXZ900 said:I considered the lighter version, but decided not to spend the money, just turn up the boost 8)
You're tight HP overcomes weight.
For you flatties the titanium kit would be a complete waste of money. In the mountains every pund counts against you. Yes, the increase in HP helps a great deal, but not in all situations. One situation where I don't think it is going to help you much is when you are stopped going down (or accross) a steep hill and you realize you need to lay the sled over and turn her back up hill. The reason that I'm not convinced the extra HP is going to help is you have NO momentum at all and you are fighting the weight and balance of the sled to get it over on it's side.
I could be wrong though. When it comes time to do the manuever above you put everything you have into tipping the sled over and you MASH the throttle. Mashing the throttle helps get it over on it's side.
POWERHAULIC
I understand spray, but I'm a flatlander so the weight is not so much a concern. 8)
MXZ900 said:I understand spray, but I'm a flatlander so the weight is not so much a concern. 8)
I agree 100%
MPI advertises 16lbs savings and the use of engine oil on their turbo. I have spoken with Bender many times and they are saying 11-12lbs savings and the oil kit will be awhile yet. MPI tends to stretch things a little. If moneys no option I think it would be worth it, but I think it would be better spent on a rear suspension. Only my opinion.
Nut sack I know the feeling. We ordered turbos in April 02' and they didn't show up until Feb. 03'. Trust me though, it's worth the wait!
