dexter
I just did mine... easy out easy in. just used the palm of my hand and easy even pressure. even pressure... or the sides will bend. I guess I got lucky?
Teamblue4
- Feb 20, 2008
- Il.
- 2012 Apex XTX
2013 Apex SE
2014 Apex SE
2014 Apex XTX
Do you have to remove gas tank to replace these gaskets?
dexter
yup... need to loosen the allens or hex heads cant remember to loosen the clamps. then loosen muffler and give it a yank out.
DigitalFusion
- Jan 19, 2011
- Chisago City, MN
- 14 Viper LTX, 10 Turbo Phazer MTX, 08 Phazer, 88 SnoScoot
the two 12mm hex head bolts under the grommets in the picture (#28/#20) are under the gas tank. The tank is really easy to remove tho. There are two 12mm nuts at the rear, two phillips screws in the side panels, two fuel lines, and two elec connectors and she slides right out.
Teamblue4
- Feb 20, 2008
- Il.
- 2012 Apex XTX
2013 Apex SE
2014 Apex SE
2014 Apex XTX
Thanks, I wanted to put my gutted muffler in but couldn't remember if I had to take tank out.
