Has anyone tried Goodwin's pin weight kit?
RX1-er-2005
Ottawa, Ontario, Canada
I'd like to use POO ramps in my YAMI clutch using this conversion kit, it allows you to use CAT/POO or COMET style ramps, has anybody used this kit and what results did you guy's get. :rocks:
You lose the adjustabilty of the rivet/weight combo. The 8dn-20/89a-10/8dn-10/8df-oo weights use the same poo/cat profile but you can use rivets to fine tune the shift pattern.
Aren't Goodwin's pin weights adjustable with set screws or something similar? Most aftermarket pin weights I've purchased for other sleds offer EASIER adjustability than the OEM weights.
But I don't know these Yamaha clutches well, so forgive my ignorance if I'm wrong on that...
