nytro addict
I'm looking to get some kind of fuel programmer for the sled. I have the CR10EK plugs, K&N's and Skins Q exhaust. Lately I've been getting a hesitation when I get on the throttle. So was thinking of some sort of fuel accelerator unit. Unless theres an easier fix? LOL
Did my searchs on here and found some about the PC3 with the pros and cons. But didn't find anything on the Hauck fuel accelerator. Does any one have one or any comments of any pro or cons on this system?
And any more help of info on both units would be very helpful !! Thanks and Happy Holidays !!!!!!!!
Santa just dropped mine off tonight (fuel accelerator),I'll be installing tomorrow after a 1/4" of ice melts off my sled.
Turk
Tech Advisor
pm me if you need a good setting for hauck fuel programmer as the set up they give you is too lean with K & N,s only. I also have settings for fuel filters plus exhaust.
Fuel accelerator did help with lean stutter but as temps dropped below 15f it was still too lean with haucks recommended settings,(stutter came back).I am running with k&n's ,header,and under tunnel dump exhaust.Turk,how much richer have you needed on yours?
Turk
Tech Advisor
Seems like every sled is different as to how much fuel it wants. i am running filters only & had to add a lot of fuel on mine.
