attak 06
- Jan 12, 2009
- Deer Lake, NL
- 2011 Apex XTX
I'm a bit new to the MPI supercharger. Where in Canada can I buy this head shim. From a yamaha dealer? Thanks in advance for any info.
machzrobbie
Hurricane can fix you up!
sheetwright
- Jul 7, 2008
- Northwoods USA
- 2021 Yamaha SRX
Yep hurricane or powderlites would carry what you need
attak 06
- Jan 12, 2009
- Deer Lake, NL
- 2011 Apex XTX
Thanks!
attak 06
- Jan 12, 2009
- Deer Lake, NL
- 2011 Apex XTX
On the hurricane site, the head shim is .060. For 0-2500ft above sea level, would this shim be too thick for the MPI supercharger on 10 lbs of boost. If so, what overall thickness should I be aiming for to get the correct compression ratio?
HURRICANE
- Oct 17, 2007
- Prescott Ont.
- www.hurricaneperformance.ca
I recommend that you use a .060 shim but be sure to set your cam timing.The engine will loose throttle responce unless your cam timing is set to 114 lobe centres.Call me and I'll help you
Dave
Dave
attak 06
- Jan 12, 2009
- Deer Lake, NL
- 2011 Apex XTX
Thanks. I assume I'll need a gauge to set the cam timing, correct?
HURRICANE
- Oct 17, 2007
- Prescott Ont.
we have a tool that we sell for that that makes it easy
attak 06
- Jan 12, 2009
- Deer Lake, NL
- 2011 Apex XTX
Perfect. I'm going to start this project when the summer heat is over, lol. There are more parts I'm going to need to install this used kit. Would it be ok for me to message you when I knows everything I needs. Thanks
Ps. I tried ur website too, but after the home page I keeps getting an error page.
HURRICANE
- Oct 17, 2007
- Prescott Ont.
I'll be happy to help when you are ready.web site is fixed now
Dave
Dave
Mountaintech
Dave
X2. When you adjust the cam timing the throttle response is the same as a stock motor. Ran a shimmed motor unboosted for a day and it had great throttle response. Really lacking in top end though.
