yamaha247365
- Jan 23, 2011
- Wisconsin
- 09' FX Nytro
Adding a header to my 09 FX Nytro. Do I need to mess with the computer? Or get a programer?
shadow44
Need more info...what header, what other mods? A header on its own you should be fine. A header with air box mod or filters you'll need to adjust fuel...easiest way is with a controller...power commander 3 or 5.
EVO can mod your stock ecu but imo that's a bad way to go as there's no going back to stock
yamaha247365
- Jan 23, 2011
- Wisconsin
- 09' FX Nytro
Excell header. No other mods.
nydiver
- Apr 30, 2015
- Syracuse, NY
- 09 Nytro XTX
09 Nytro RTX
91 Phazer II (gotta have a classic / kids bomber :) )
Header alone won't change the flow rate thru the system nor really do anything for you without supporting mods, you should be fine with stock mapping.
Big_Phil
- Feb 5, 2014
- Wasaga Beach, Ontario
- Sidewinder RTX LE
My brother ran an excell header and a hollowed out stock muffler for about 5000kms with no fuel controller last year, never had a problem. Fuel controller is the proper way to do it tho.
How come you are putting the excell header on? I dont think the header alone will add any hp without a fuel controller and muffler. Maybe 1-2 hp. Youd be better off spending that money on a clutch kit or k and ns.
yamaha247365
- Jan 23, 2011
- Wisconsin
- 09' FX Nytro
I got one of there headers to make an under tunnel exhaust. I just wanted to know if I needed it. I will be getting an after market muffler and I have a modified intake and a power commander V on the way. Thanks for the responses. I decided that if I keep this sled long enough to save me from buying another new one, I'll throw a couple bucks at my current sled and run it longer. Probably going to get with Schmidtbros for some clutching.
- 7K
