heat exchanger question
srxguy
Upstate NY
Ok guys I have a question....I bought a 03 rx-1 that was originally a 121 track and was ext to 136. Now the question I have is I want to buya rear heat exchanger, so do I just buy one for a 121 or what?.Thanks for the help guys!............. :jump:
What is the extension that was used to stretch the sled? I would pick up a mountain cooler for it. Depending on the design of the extension it could be easy to install or require some thought.
Tripple x said:
if you have 136" track,,i would use a kit from a warrio
r, do you have a tunnel extension on the rear ?
.......................................................... Yes It has been extended to a 136 track..The crossover tube is in the stock 121 location, can't I just put a 121 cooler back there?
Are you studded? If so, you'll likely hit the exchanger with the studs....May have to get the Warrior/Mountain exchanger tubes modified to give more length. You'll also need an extension to the protectors to cover the heat exchanger (unless, of course, you aren't studded).
..Yes it is studded, I thought I read somewhere you did not need protectors with a 121 but u did if u had a 136.....Not sure?
