heat exchanger ?
Elk Grove, CA
2012 nitro mtx 162
where cani get a rear heat exchanger for my attak for a reasonable price.
the dealer wants something lke $250.00 - $300.00 for one. i thought that you could get one for around $80.00 - $100.00
any help would be appreciated.
heat exchanger
thanks guardrail for the info. do you have one of these on your sled and if so how do you like it
thanks
Yeah, I put one on mine when I bought it. I had problems with my Rxwarrior heating up. I put one one on that sled and it fixed the problem. Make sure you thin out your antifreeze to about 60/40, that will cause a heating problem also.
heat exchanger
thanks for the info it sounds like this is the way to go to prevent any problems. are they difficult to install?
I do not know how difficult the Attak install is, but I can tell you that the Apex cooler was only about a one hour job for me.
Having a die grinder and an air rivet gun made the job quick & easy.
Simple job to do. I don't think you get protectors with the cooler. I didn't.
I went to HomeDepot and bought some Aluminum straping and square tubeing and fabricated one. I ran it for a while without protectors and had no problem. I don't have studs and run stock. I'm a big guy and thought I'd tear up the protector. I made them anyway just to be safe and I might stud them this year.
Get in touch with Kevin at Port Yamaha www.portyamaha.com
Charger,
Make sure you compare pricing with Pioneer.
Please also add your location to your profile.
Welcome to TY!
My Apex rear heat exchanger from Pioneer was a genuine Yamaha part. I see Bruce has raised the price on the heat exchangers since when I bought mine last year.
The Apex rear heat exchanger went from $81.95 to $129.95 and the Attak rear heat exchanger went from $169.95 to $199.95. Still well worth the extra peace of mind IMO.
thanks for the info. am i to understand that i will need to fabricate a shield for this, and do the kits from pioneer come with all mounting hardware?
does the 09 apex came with a oem rear heat exchanger?
if so. price and part nr.
//Micke
