charger0926
- Sep 3, 2008
- Elk Grove, CA
- 2012 nitro mtx 162
where cani get a rear heat exchanger for my attak for a reasonable price.
the dealer wants something lke $250.00 - $300.00 for one. i thought that you could get one for around $80.00 - $100.00
any help would be appreciated.
charger0926
- Sep 3, 2008
- Elk Grove, CA
heat exchanger
thanks guardrail for the info. do you have one of these on your sled and if so how do you like it
thanks
thanks
Yeah, I put one on mine when I bought it. I had problems with my Rxwarrior heating up. I put one one on that sled and it fixed the problem. Make sure you thin out your antifreeze to about 60/40, that will cause a heating problem also.
charger0926
- Sep 3, 2008
- Elk Grove, CA
heat exchanger
thanks for the info it sounds like this is the way to go to prevent any problems. are they difficult to install?
Blue Dave
- Jan 7, 2008
- Ham Lake, MN
- '17 Sidewinder LTX DX
I do not know how difficult the Attak install is, but I can tell you that the Apex cooler was only about a one hour job for me.
Having a die grinder and an air rivet gun made the job quick & easy.
CaptCaper
- Jan 1, 2007
- Northern N.H.
Simple job to do. I don't think you get protectors with the cooler. I didn't.
I went to HomeDepot and bought some Aluminum straping and square tubeing and fabricated one. I ran it for a while without protectors and had no problem. I don't have studs and run stock. I'm a big guy and thought I'd tear up the protector. I made them anyway just to be safe and I might stud them this year.
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Lakselv - 70N & 25E
- Norway
charger0926 said:where cani get a rear heat exchanger for my attak for a reasonable price.
Get in touch with Kevin at Port Yamaha www.portyamaha.com
charger0926
- Sep 3, 2008
- Elk Grove, CA
thanks i will give him a try
Blue Dave
- Jan 7, 2008
- Ham Lake, MN
Charger,
Make sure you compare pricing with Pioneer.
Please also add your location to your profile.
Welcome to TY!
Welcome to TY!
Timeline
- Jan 1, 2008
- Orangeville & Wasaga Beach Ontario
- 16 APEX XTX
Anyone know if Pioneers is the same as the factory one that Port sells? Any difference? Price seems to be the same.
Blue Dave
- Jan 7, 2008
- Ham Lake, MN
My Apex rear heat exchanger from Pioneer was a genuine Yamaha part. I see Bruce has raised the price on the heat exchangers since when I bought mine last year.
The Apex rear heat exchanger went from $81.95 to $129.95 and the Attak rear heat exchanger went from $169.95 to $199.95. Still well worth the extra peace of mind IMO.
charger0926
- Sep 3, 2008
- Elk Grove, CA
thanks for the info. am i to understand that i will need to fabricate a shield for this, and do the kits from pioneer come with all mounting hardware?
Timeline
- Jan 1, 2008
- 16 APEX XTX
Thanks Blue Dave.
