chadman
Can we use our cigarette lighter port on our apex for a heated shield?
yox185
Yes get one of these. http://www.jrgraham.com/itemdetail.do?action=prepare_detail&itm_id=133852
chadman
Thanks alot for the reply.
Irv
- Mar 23, 2005
- ONT. Canada
1995 XLT SP (Son's)
chadman said:Can we use our cigarette lighter port on our apex for a heated shield?
I was going to go that route too but heard they fall out regularily?
I ended up wiring mine directly to the battery but just found out I could have wired it directly to the battery leads that come out the right side for charging/boosting.
theCATman
- Feb 19, 2007
- WI
- Yamaha
yox185 said:Yes get one of these. http://www.jrgraham.com/itemdetail.do?action=prepare_detail&itm_id=133852
Yep. It can be done, but an adapter is needed.
If you were to just splice a DC plug onto the visor wire, it will blow the little 3a fuse every time.
Gone Blue
- Oct 11, 2006
- Howell, Michigan
Dont waste your money, buy the Yamaha one. Yamaha has an accessory plug with a multiple ring seal around the plug that helps it stay in the socket. Yamaha makes one with the RCA on it already or a generic one that you can wire anything to it. I bought the generic Yamaha one and wired an RCA plug to it because it was cheaper. It works great. When I added a GPS the 12V plug that came with the GPS wouldnt stay in the socket because it did not have the seal on the plug. I wound up adding a second lighter socket under the hood for the GPS so I could use both the heated shield and the GPS. G.B.
darv
- Aug 9, 2005
- International Falls,minnesota
- 08 Apex 40th LTX
I just purchase the switch from yamaha and spliced the wire that goes to the cigarette port
Honk
Mine always rattled out of the assy plug. Rewired to fuse box, no probs
NY_Nytro
- Dec 24, 2004
- Grand Island, NY
- www.gi-snowmobiler.com
I always wired to the fuse box. Pull one of the fuses, feed the wire down by the prong and reinstall the fuse to hold it in place. Put the wire on "fused" side and you'll have safe connection.
