DM7
- Aug 25, 2008
Hi ! I have a FX Nytro XTX 2011 and i want to change my rear coil spring for heavy duty one. What is the Yamaha part number for these coil spring ? Tank's !
nitro xtx had torsion springs at the rear and a coil over shock at the front of the skid. you could just put the ones from an 11-15 apex xtx in there.
Broue
- Feb 28, 2015
- FX Nytro XTX 2009,
Factory race front end
Star suspension relocation kit and revalve
Ski Doo #503192064 center spring
135 mm idler wheels
Oilite bushings
Grizz steering relocator
Tuner ski : 6 ''carbides,
WRP seat
Vector gauge
Custom Taillight
LinQ tank
Sno Sport 1990
Ski Doo Tundra R 1998
for an heavier coil over spring (center shock) : you can use a Skidoo part # #503192064
CJW1
- Sep 9, 2014
- S,E Michigan
- 09 Nytro xtx
I have a set of heavy torsion springs for it. I had them on my 09 nytro xtx. I used them for 1 trip and found they were to stiff. I’ll give you a great deal if you are interested.
kschitoskey
- Aug 22, 2015
- Central Oregon
- 09 Nytro XTX
07 Phazer
94 Polaris 440
I went the ski doo painted spring route as well. I'm a 270 lb rider and it works great.
Ethan_Messinger
- Jan 17, 2016
- Wisconsin
- 2011 Yamaha Nytro XTX
2100nmm torsion springs. i put those in from an apex MTX and cut to correct length with a saw
Mark1894
- Apr 3, 2018
- Iowa
- 2009 Yamaha Nytro xtx
I just purchased a 2009 fx nytro xtx and my wife rides double with me most of the time will the stock torsion springs Work for us or do we need heavier ones? Combined weight 440-450I have a set of heavy torsion springs for it. I had them on my 09 nytro xtx. I used them for 1 trip and found they were to stiff. I’ll give you a great deal if you are interested.
CJW1
- Sep 9, 2014
- S,E Michigan
- 09 Nytro xtx
The ones I have are the heaviest they make. I was 290 lbs when I ran them and never once bottomed out my rear suspension. If interested let me know
Hooray!
- Aug 12, 2017
- Maine USA
- 2009 Yamaha FX Nytro XTX
1998 Yamaha VMAX 700 XTC
How many torsion spring weights do they make above stock? I am 220lb. geared up and when riding aggressively even on hard setting I will bottom out on those 85mph unexpected whoops, spine crushers... Don't want crazy stiff but need more there than stock torsion springs can give. Maybe there is a next stiffness up spring or only the one you have?The ones I have are the heaviest they make. I was 290 lbs when I ran them and never once bottomed out my rear suspension. If interested let me know
CJW1
- Sep 9, 2014
- S,E Michigan
- 09 Nytro xtx
Mine are the ones above the factory springs. I went back to the factory ones
Robbie Royal
- Oct 14, 2018
- Nfld
- 2013 nytro xtx
hello, I’m new to Yamaha Nytro, and this site. I plan on riding 2 up from time to time and when myself and my wife got on, just see what it was like it bottomed out right away. It is on the softest setting but even on top setting I don’t think it will help us. If someone is Selling a set of heavy duty springs or you know of an after market set that works. That would be great thanks
CJW1
- Sep 9, 2014
- S,E Michigan
- 09 Nytro xtx
I heavy a seat of heavy springs. If you are interested let me know. I can send pics if you would like.
Robbie Royal
- Oct 14, 2018
- Nfld
- 2013 nytro xtx
Thanks yes that would be great!! Let me know how much you would sell them for? And hopefully we can work something out.
CJW1
- Sep 9, 2014
- S,E Michigan
- 09 Nytro xtx
Check your pm
TomahawkMBM
- Dec 16, 2018
- South Central Michigan
- 2010 Nytro XTX
Springs still available??I have a set of heavy torsion springs for it. I had them on my 09 nytro xtx. I used them for 1 trip and found they were to stiff. I’ll give you a great deal if you are interested.
