Turk
Tech Advisor
This was with a g-g-g spring. I don,t have a clue for codes on the roller. If you try the red then u gotta add a ton of weight to overcome the spring...no thanx. I prefer a wimpier spring & lighter mass in the weights.
**sj**
I like your thinking....what's your guess for a spring on an attak using the 38-20's
Turk
Tech Advisor
Try a p-g-p with weights empty to start & fine tune from there.
70superbee
So has anyone tried any runs with drag&fly weights yet? If so what could you tell about them? Was talking to Randy at the Millwaukee show, and recommened them for my 06 attak. Or am I better off with two speed weights. I used to run them in my polaris sleds and they worked really good.
Rich
Rich
Turk
Tech Advisor
Drag & flies are too new yet for a lot of well tested input on snow.
**sj**
your bio states you already have a "clutch kit"....not happy with it?
as Turk said...new...but the basic design reminds me of his original (a gem)..the squeeze down low with no clutch cutting now!
it might come down to how much you want and what type of riding do you do
70superbee
No I like my pro line kit. But there are times I do get some belt slippage.But like I said used to run the 2 speed weights in 2 of my old polaris sleds, had them dialed in really good. Clutches were cool and got over 1700 miles on my belt in my old 900 SB. Just looking for a little better set up. If it is possible.
Riding varies from lake racing to club rides, to playing in the powder.
Rich
Rich
**sj**
if you take a minute and look at the drag n flys....essentially they are the original heelclicker without having to cut (notch) the clutch...
my improved srx loved those clickers!
I think for the guy wanting a bolt on weight without too much tuning or comprimise they'll be nice..
70superbee
So Iam still wondering if anyone has run the Drag&Fly weights yet.If you did how are they?Just want some feedback before I get a set.
Thanks Rich
Thanks Rich
1badattack
I have them and got really good results, picked up 2 tenths in 500' on grass.
**sj**
NICE...POST YOUR SET UP???
1badattack
sj said:NICE...POST YOUR SET UP???
I'm not going to post my set up, as every sled is different and this set up works great on grass, to early to tell on the snow, but I will post my results after testing. For now here are my results of what iv'e tested.
500' on grass with Brower timing system.
Drag-N-Fly weights--------5.91
Heavy Hitters-----6.13
Proline clutch kit-----6.11
Stock Weights-----6.17
**sj**
I've said it before and will again...nuttin hooks like a set of clickers!
**sj**
here's one setup to try..
white spring...4.7 heel
5.2...0.0...4.2
5.2...0.0...4.2
Charged RTX
SJ is this what you are using with your 38-20? How did that work out for you?
