heelclicker clutch help!!!!!!
rx1viper
n.w. ohio
I had heelclicker's in my 03 RX1 and ran fine with a 4200 rpm clutch engagement. I called supertorquer and asked them for a set-up for my warrior (reminding them that the warrior has different size rollers) they told me to put 3.3 in the tip and 3.3 in the heel which is the same as the RX1. Now I have a 6500 clutch engagement!!!!!!!!! Any one have the correct set-up, I'm leaving for the U.P. within hour's. :cry:
Most dealer's in my area don't stock roller's so I'm screwed there. I can't believe supertorquer doesn't know this.
5.0 in the heel, 3.3 in the tip works real good, i used stainless socket cap machine screws i got at the hardware store , the lock washer and 4 of the heelclicker washers to get it, engagment is 4300, and slams right to 10200
ps i ran 4.6 in the heel last year and the engagment was 4700 or so and you can do that by running the stock secre with the same configuration of washers as i mentioned above
