Help 2004 Rx Warrior
yamaha rider
portgae pa
i have a 2004 Rx warrior and i put on 300 miles on this year so far and it ran amazing. When i was out lastnight it ran great then all of a sudden it had no power and would not go above 4 thousand rpms.... could this be a a blocked jet? any help would be greatly appreciated!! Thank you!!
Sounds like t.o.r.s. is kicking in more than likely carbs are dirty but check throttle cable to make sure it ain't binding first Also check plugs might have fouled them but I'm leaning towards carbs and or cable hope this helps
I agree with Brian. Start with carbs and then plugs.
