2004rxwarrior
Hey Guys,
On two recent ventures out I have blown a belt on each trip.
Has anyone had similar issues? The sled has worked perfect up to now.
>2004 RX Warrior.
>6500 miles on the sled.
>Just installed new track for this season.
>Both belts were Yamaha OEM.
Any help is very much appreciated!!
>2004 RX Warrior.
APEX 06
- Apr 30, 2009
- Sheboygan, WI
- www.sheboyganyamaha.com
- 09 Nytro XTX, 08 Apex Mtx
when was the last time the clutch's rebuild or clean.
2004rxwarrior
The clutches have never been rebuilt.
They have been cleaned before but not very thoroughly.
dexter
I just rebuilt my primary and secondary at 12kmiles... what a differnce. just unreal, and they werent too bad, but I am not a hole shot guy... long squeeze. I also wash my primary in the dishwasher once a year, blow them out and scotch brite the sheeves. a must that a lot of people overlook.
tedgoesfast
it has to be heating belt to blow it inspect clutches completly iam sure you will find something going on
buddah
- Apr 14, 2003
- Wetmore, MI
- '17 Sidewinder B-TX LE
Did you wash and dry the belts before installing them? They have a coating on them from the factory to prevent mold (I think it is) from forming which should be removed before using. Also, did you break the belts in or just run the *&^% out of them?
As somebody already mentioned they will usually only blow due to excess heat........something is causing the belt to slip thus building up heat..........
