rx1wizard
2004 warrior with only 2100 miles. Happened last year almost like hitting a brink wall at 6000 rpm can use choke to get it a little passed it but will back fire letting throttle off. Over summer cleaned out 3 each jets in each carb think the the mains were it, but not to be took out today and same thing. Took plugs out look good, anyone have any suggestions, still in carb or clutches? :exc:
Clean your carbs and make sure you dont mix up the main jets with your power jets. Your main jets will be marked 135 on them. Get some allen head carb bowl screws from sledtoyz and change them out as well. Make sure your pilot jets are clean clean clean add some seafoam to your gas and fill it up with fresh gas as well.
Indy
Sled Dog said:Clean your carbs and make sure you dont mix up the main jets with your power jets. Your main jets will be marked 135 on them. Get some allen head carb bowl screws from sledtoyz and change them out as well. Make sure your pilot jets are clean clean clean add some seafoam to your gas and fill it up with fresh gas as well.
Yep, as Sled dog always says, clean your carbs, and if that doesn't work, clean them again.
apracing
- Feb 19, 2013
- new brunswick
- 2004 rx1 warrior 2006 apex gt 1979 enticer 340
i did mine three time ...tricky little suckers
