Barney Maclean
- Oct 15, 2014
- ontario
- 2016 Yamaha Viper RTX SE
Hey Guys im sorry if this dog has been beat to the dirt! But my sons 2008 Nytro has NO power when key turned on? Yes kill switch is out
battery has 12.3v across, All fuses look to be OK! I just had it running but now nothing? My first Yamaha!
Thanks for any Help!
Barney
Barney
mnman309
I bet if you take the starter solenoid off it is all green and corroded, they are known for having issues. I replaced mine when it was doing the samething. You can try and jump across the terminals with a screw driver to see if the engine will start. Be careful so you dont weld it on there!
derek_thompson21
- Oct 20, 2014
- 2008 Yamaha FX Nytro MTX 153"
I second the starter relay.. did lots of research on them myself and ordered a spare for my backpack.
Barney Maclean
- Oct 15, 2014
- ontario
Which one is the starter relay?I second the starter relay.. did lots of research on them myself and ordered a spare for my backpack.
Thanks guys
mnman309
It is about a foot to the right of the battery, follow the battery cable to a solenoid switch/relay.
Barney Maclean
- Oct 15, 2014
- ontario
Haha! A skidoo Buddy of mine removed it! What a Jurk!It is about a foot to the right of the battery, follow the battery cable to a solenoid switch/relay.
Thanks guys!
allyammies
Kind of funny.
R00STER
- Mar 3, 2013
- Timmins, Ontario
- 2013 Nytro xtx 1.75
He figured that was the only way to beat you in a race
grizztracks
TY Advertiser
- Feb 24, 2005
- Scio, NY
Another common problem is corrosion in the key switch connector. I've had mine act the same as you have described. It works then the next try there's nothing. More trouble shooting info here: http://www.ty4stroke.com/threads/starter-system-troubleshooting.105358/#post-931403
