woolyviper
- Mar 24, 2006
- hibbing,mn
- 2009 Yamaha Phazer RTX
looks like a bolt that goes thru the side frame or the subframe.
xt_gt
spike337 said:Speaking of working on clutches, i use to have my Doo and Polaris ones off almost every ride or two just to try new stuff and clean. I bought a puller for my Phazer the day i picked it up, still in the package. I blow them out, which is real caveman cheezy i know, but besides secondary buttons, i can't see a real reason to mess with it the way it's designed.?
If i do, what do you torque the primary bolt to?
book says
85 ft. lb 1st &
43 ft. lb 2nd
tatalover78-2
I thought subframe also. all the bolts are there, all the green bolts are in the correct location and all others are grade 8.8.
Can anyone check the cross bar that holds the bottom of the limiter strap and see if it has the same "9" marking on the bolt head
thanks
thanks
- Nov 1, 2009
- Winnipeg, Manitoba
- 2009 Phazer RTX
tatalover78-2 said:I thought subframe also. all the bolts are there, all the green bolts are in the correct location and all others are grade 8.8.
thanks
It sure does
tatalover78-2
thanks much
