Trying to figure out what my turbo Nytro will sometimes keep the revs up (4k or so) after I have let the throttle go. I've checked the throttle cable and it's not sticking. If the throttle bodies are closed and for some reason it's still getting fuel, wouldn't it flood?
I've discovered that if I pull the vacuum line off the boost gauge the revs will drop and although it runs rougher, it won't do it anymore
Any help would be greatly appreciated.
HURRICANE
- Oct 17, 2007
- Prescott Ont.
- www.hurricaneperformance.ca
We just ran into the same problem in the shop on a Nytro.It turned out to be no power at the idle motor.There was a pin out in the harness
Mtn-Track
Idle motor?!? Please explain.
mulot30th
- Jul 7, 2007
- youtube.com
- 2023 thundercat
apex mountain crracing 174
apex blower 136 for asphalt racing
osp drag race sled (apex engine based)
does the nytro run a IAC?
HURRICANE
- Oct 17, 2007
- Prescott Ont.
The Iac(idle motor) is near the centre throttle body ahead of the gas tank
Thanks Hurricane,
did the sled throw a trouble code when the wire was not connecting?
HURRICANE
- Oct 17, 2007
- Prescott Ont.
Yes it did.I can't remember what the code # was but it did represent the Idle motor
G
