unreal
I have a 2006 Apex Mountain that runs on at midrange when your light on the throttle just like the cable is sticking. It only does it when you feather the throttle, if you hit the throttle in a snap like method it idles down fine. I changed Cable, no help. I checked secondary thinking it might be a backshift problem, no help. Tried to go lean and rich on Gems controller, no difference. Any help would be greatly appreciated.
Ted Jannetty
unreal said:I have a 2006 Apex Mountain that runs on at midrange when your light on the throttle just like the cable is sticking. It only does it when you feather the throttle, if you hit the throttle in a snap like method it idles down fine. I changed Cable, no help. I checked secondary thinking it might be a backshift problem, no help. Tried to go lean and rich on Gems controller, no difference. Any help would be greatly appreciated.
A Vortech bypass valve will elimintate this problem.
Ted.
Yes my Nytro did the same thing! (UNSAFE) now with BOV all good!
Skydog
Skydog
gsxr
- Feb 24, 2006
- BRACEBRIDGE , ONTARIO
- 2023 SRX
yes , add a vortex bov ! call Ted
Ted Jannetty
gsxr said:yes , add a vortex bov ! call Ted
Vortech LOL!
chuckr
which one
should i use to get 10#, the Maxflow says 8# at 320 CFM and the Mondo does not list where it opens or CFMs or is the Mondo adjustable
Ted Jannetty
Re: which one
That is just a flow rating to give you some Idea how much air it can move on Decel.
It is closed at all boost levels and opens when you let off the throttle or any time there is more than 1.5 inHg vacuum or more in the throttle bodies.
This is the right bypass valve for all turbo and supercharged snowmobiles.
http://turboaddictionparts.com/catalog/ ... ducts_id=3
The Mondo is Just too big.
Ted.
chuckr said:should i use to get 10#, the Maxflow says 8# at 320 CFM and the Mondo does not list where it opens or CFMs or is the Mondo adjustable
Ted.
unreal
Thanks Ted and everyone else for the advice, I got it installed and tried it out today. IT WAS AWESOME!!! Works like a charm, the most fun I ever had with it. THANKS AGAIN TO EVERYONE!
Re: which one
Ted are these blow off valves supposed to let air come out at idle or only on deceleration. I have the vortech and it lets air out at idle and higher on the stand, is this normal?
Ted Jannetty said:chuckr said:should i use to get 10#, the Maxflow says 8# at 320 CFM and the Mondo does not list where it opens or CFMs or is the Mondo adjustable
Ted.
kinger
Yes that is normal. Under full load which your NOT at on a stand it will close up and not let ANY air out. Otherwise at light load and idle it will let air out which is a good thing as its excess pressure anyway and would otherwise heat up the IC and strain the engine to have to always have pressure built up when you dont need it.
