Turk
Tech Advisor
Try this
1 bolt 5 washers arm
4,2 centre
overdrive empty
4.2 in tip.
The shoulder gives you the low & mid & your pretty light there.
4,2 centre
overdrive empty
4.2 in tip.
CANAM 4 Stroker
- Oct 26, 2005
- www.klim.com
- 2009 Yamaha Apex GT
Thanks for the recommendation. Just checking...this will raise the rpm on the top end ? Earlier in the post I explained that I was flattening out at 10500 and needed to get to 11000. I suspect that you saw this but just checking, as the snow is at a premium around here ! Lol
Thanks.
Thanks.
Apex809
What do you guys recommend for long tracked 136 apex with 168 studs. Motor all stock and stock gearing. Looking at the Drag-n-flys. Which gearing should i go with? Currently comes out of the hole around 9500-10,000 and slowly climbs to 10,700. I have lost a lot of topend since i went from 121-136.
CANAM 4 Stroker
- Oct 26, 2005
- www.klim.com
Turk said:Try this
4,2 centre
overdrive empty
4.2 in tip.
Turk,
I see from some prior communication on this subject that you are expecting 10,700-10,900 rpm from this set-up. That answers my inquiry of what results you expected me to get from this. Thanks.
go with turks set up on your weights.
then change your gearing to 23/40 and you will rock.
69redmach1
Make sure you're running a new belt. It makes a difference on the GT/Attacks.
