GMC1
Need help on trying to figure out on how to tell if my front end is bent. My son hit a rock head on right under the front bumper. He said that he was doing 10-15 mph. I dont know what to look for i hope the front end isnt bent any info would be great thanks.
lucky_7
Start by checking to make sure the shocks are centered in the a-arms, the spindles look like the same angle, and that one ski isn't in front of another.
Make sure you do this on flat ground
Grimm
- Apr 15, 2005
- Ottawa, Ontario
- 2018 MXZ 850
Check ski toe in/out, Yamaha specs them at 0-15mm toed out.
How about the skis? Is one ski further forward than the other? Take assorted measurements and compare them to the other side of the suspension.
Did you look under the sled to see what kind of damage the rock caused?
Take it to your dealer so he can see it. No one on here can fix it!!
fxnytrortx3
just a quick check drive it straight ahead to a wall until the skis touch the wall and if only one is touching then you no something is wrong or you didn't drive it in straight.
darren
darren
Tom-RX1
with a head on hit check to see if all the plasic parts fit . if they all fit should not be bent .
Tom-RX1
Tom-RX1
GMC1
thanks everyone for the help ill check it todayTom-RX1 said:with a head on hit check to see if all the plasic parts fit . if they all fit should not be bent .
Tom-RX1
- 45K
