rtx moose
- Jul 31, 2014
- WATERTOWN,MN
just ordered oilites from BOP and the bushing OD measures .830 and i measured the bulk head hole at about .730!!!it seems the bushings are much bigger than the bulkhead hole..can someone help me out ASAP
RAMSOMAIR
There should be at least 3 different bushings. Make sure you have the right ones in the correct positions
rtx moose
- Jul 31, 2014
- WATERTOWN,MN
I do.i even went to dealer to buy plastic ones and they seem small too
RAMSOMAIR
Time to give Travis a call. I’m sure he will be able to help.
Not trying to be a smart #*$&@ but have you removed the old bushing. I bought the same kit and some of the bushing are snug but everyone in the kit fit
rtx moose
- Jul 31, 2014
- WATERTOWN,MN
Just figured it out,got the wrong bushing...needed to order bulkhead bushing and i have a arm bushing...what a dumb a$$ i am
Even with the right bushing fit is tight. Piece of 1/4-20 threaded rod with a couple washers and nuts help suck them in. Good video on YouTube showing complete apex bushing replacement.
rtx moose
- Jul 31, 2014
- WATERTOWN,MN
so the bushings are all the same for lower bulkhead holes right?
Mileage Quest
THIS or expect to order more bushings after you wreck a couple
Yesso the bushings are all the same for lower bulkhead holes right?
