Help needed - 2006 Vector engine failure
birkebeiner
Norway
Norway
2015 Yamaha SR Viper X-TX
My '06 Vector Mountain with 7,000 km / 4,400 miles on it had an engine failure a few weeks back, on my first ride of the season.
The dealer has opened up the engine and says the sprocket / gear on the crank shaft that drives the cam chain is totally gone (?) and therefore all valves were left in open position, resulting in a dead engine.
This happed while I was driving and the engine just died. I wasn't doing more then maybe 40 mph when all of a sudden the sled stopped. No noise, nothing. It was just like it ran out of gas or turned off the key.
Now I have to change the engine because the crank case, crank shaft and cylinder head with valves are gone.
Is there anyone out there that have had a similar issue? If so, what model and year? I know there has been a lot of talks about the cam chain tensioner on this forum and the dealer says this was something they changed up to 2005 models. Just thinking, if this was a known issue pre-2006, it might as well be an issue on a 2006 engine as well...?
Would like any information you might have, especially if it's on a 2006 or later model year, so I can use this info to get Yamaha (not the dealer) to pay for at least some of the cost!
:4STroke:
yamaha will not help you. it has to be caught while its making noise, before damage occurs. even then, you pay to have the tensioner replaced. a lot of people have had them changed. there is an updated tensioner. its such a major job to replace it that yamaha is not helping many people, because it would be big bucks to them.
