xprtrpr
Hello, OK, so I did an oil change on my sled tonight. I have a couple of questions...
1) While checking the oil level, somehow I lost the little "plate" at the bottom of the dipstick. So now instead of a cylinder with a closed bottom, it is open (now the tan cylinder part rides up the little poles it's attached too when putting into reservoir), guess where the plate went?? Into the oil reservoir!! So, my question, is there an easy way to get this thing OUT of the oil reservoir? If I drain the oil again (which I have to do anyway, somehow I didn't notice that one of the washers came off from one of the oil drain bolts. So, I button up sled and fill oil, and check oil, lose the plate, and in my annoyance never say the washer until the drip pan drained. IDIOT) and I take off the bottom section where the screen is, do you think the plastic piece will come out? Can I shine a light in there and root around with a screwdriver or something to get this thing out of there? If I can't get it out, is this thing going to cause a legitimate restriction of oil flow?
2) I also changed the filter, and I went to Yamaha dealership, without manual, and they gave me an oil filter. I take off old filter and go to verify the part number and it's off by a little bit, instead of 00, it's a 20 at the end of part number. The difference that I can see is it is about 1/2 inch shorter. I put it on for now, hoping that dealership knew what they were giving me, and coming to you guys for guidance, does it really matter if the filter is a little smaller? Not trying to sound ignorant, just would like info from you experts.
Let's see, anything else I screwed up tonight? hmmm, I can't remember....
Thanks for your help in advance!!
