Remove airbox (hoseclamps),
Remove carbs (hoseclamps)
Flip carb rack upside down, put an old bed sheet under it in case you drop anything.
Use a VERY CLEAN AND PERFECT CONDITION #2 philips to remove float bowl screws, be VERY CAREFUL not to strip the heads, the bolts are VERY SOFT.
Use plenty of carb cleaner spray, and a very thin piece of wire (unwind a piece of aircraft cable). Lather it with lots of carb cleaner and poke the wire through all the jets (brass things with small holes in the middle), then reassemble.
When reinstalling the carbs and airbox, MAKE ABSOLUTELY SURE that you seat everything fully. The carbs seat with a "plunk" (that you *feel*). Stick your fingers into the rubber throats on the airbox to make sure that it is inserted correctly over ALL carbs.
