Had the tank off to replace donuts and plugs, now when I turn the key nothing. No dash illumination, no start. Battery is fully charged. Fuses good. Everything was fine about a month ago when grass drags were in full swing.
Any suggestions on what might be wrong or where to start?
- Nov 1, 2009
- Winnipeg, Manitoba
- 2009 Phazer RTX
Is it like the phazers? When I take the top cover off to take off my tank I have to unplug my ignition switch to get it off. Kill switch get pushed without you knowing? Its happened to me.
Just have to unplug fuel pump, which I plugged back in. Kill switch off, but it's dead like the kill switch in on. Thanks.
Mazz
- Apr 18, 2010
- Esko, MN
- 2008 Fx Nytro RTX 40th
Sounds like you checked it already but just a stupid thing I did once, was leaving the ignition unplugged. Otherwise I would say turn your key on and cross the leads on the starting relay and see I it turns over, but even if that's the case an the relay is bad you should still have gauge lites.
- Nov 1, 2009
- 2009 Phazer RTX
Make sure the connection is good at the battery, and the battery has a good ground.
s1d3w1nd3r1480
Mazz said:Sounds like you checked it already but just a stupid thing I did once, was leaving the ignition unplugged.
x2 on this. So simple but easy to miss. When I installed my Tether/ROV and went to start the sled afterwards nothing... Double checked everything and then like a slap in the face realized I simply forgot to reconnect that d*** little plug.
Thanks for the suggestions, will tripple check everything.
waldo1
its the starter relay most likely right by the battery - check the fuse on relay 1st - 08 and 09 had this issue alot
xrrider
Probably not the problem, but did you check to see if the kill button is depressed?
AttakDog
I had my ignition switch go bad last year, just another thing to check
AttakDog
grizztracks
TY Advertiser
- Feb 24, 2005
- Scio, NY
If not a relay problem check the ignition switch connector for corrosion. It's located on the top right of the steering loop. The connection tends to get overlooked when checking for corrosion issues.
