myyamaha
hello I have 9 tooth anti-ratchet drivers I lost the directions I need the measurement for the drivers I have had them cut down!!
U can email the measurements to me or just post in on here!
monka01833@yahoo.com
thanks
mike
thanks
mike
myyamaha
O these drivers are for a Rx1 :ORC
spray25
If memory serves me correctly it is 4.5 inches to the first one and 8.875 to the second one. This is measured from teh NON-splined end to the center of the teeth. Double check the alignment before you bolt everything back in.
Also MAKE SURE you take them to a machine shope and have them trued in a lathe before you install them.
myyamaha
spay thanks for your help what other site can U get help like this!!
thanks
mike
thanks
mike
i just installed a set on my viper and found that the tips had to be cut down to clear the w arm. i did this after it was installed with a chisle to save removing it. it was about 3/16 off each one. this gave me 1/8in clearance to the w arm. before this i could not turn drive shaft over.
hope your not doing it for weight savings as they only save 1/2 lb over the stock drivers
myyamaha
viper are the mesurements spray gave me right. just want to make sure.
thanks
mike
thanks
mike
