hey guys.. getting the check engine light on, on my 2010 vector ltx. says code 84 (which is the TORS I believe) I used the steps from the FAQ sticky and cant seem to get the light to reset... this is what i'm getting
Hey, you have to get into the diagnostics in the screen and clear them. Here's how,
- push and hold the reset and select button in with the key off
- turn key on while still holding buttons in.
- hold for approx. eight seconds and the word "diag" should appear- "diag" doesn't appear d1 shows up
- push and hold the reset and select button again for two more seconds until the "01" appears- d1 Appears
- use the select and reset button to go through the numbers till you reach the number 61 and 62
- 61 shows which code you have and 62 shows # of codes in the system- 61 reads 00 and 62 reads 01
- go to number 62 and press the hand warmer switch up or down to erase the codes.- the handwarmer switch does nothing to the codes
- turn off key to reset gauge
Anyone have some ideas?? or tricks
