Hey everyone! My Jack shaft bearing went out on my 06 Apex and took the speedo out too. I’ve since fixed them both but can’t figure out how to clear the error codes. I’ve done the hold select and reset down and turn the key to get into the error code listing, was code told to go to code 62 and use the hand warmer switch to clear them. I can’t get the code to clear. Any additional advice?
Have you fired up the sled and tried to spin the track? I’ve seen speed sensor codes not want to clear until the ECU sees a few revolutions of the track with a good sensor.
