Help with clutch kit for 03 RX-1
hotrodsrx
Toluca, IL.
Guys what clutch kit would you recommend for an 03 RX-1 that is studded with 192 studs? Also looking at adding an ECP kit as well.
clutching
what are you runing now?and under what condtions do you ride? ie flat land , lake,s mtn, powder, drag raceing.
Sled is all stock with the addition of 192 studs. I ride mostly groomed trails in Wis/Mich.
I'd say I love aggresive trail riding but don't want a race setup that can't be ridden on the trails. The trails are where I spend 95% of my time.
I am also looking for something in kit form because I don't have clutch tuning experience.
Thanks for the help
I had Heavy Hitter set up kit from the Speed Shop that I purchased through them. Matt set it up for a 03 RX1 with the ECP kit. It worked real well and I saw an increase of better than 1 MPG over stock with both kits installed. I have since then bought an 06 APEX GT and sold the RX1. I have already sold the ECP kit, but I still have the Heavy Hitter set up with clutch spring, helix, primary rollers, and 48g weights set up for the 03RX1 that I am willing to sell for $200 plus shipping. Let me know if your interested.
Thanks for the offer. One of my buddies bought a used clutch kit off here before and got screwed. Just trying to be safe.
Thanks for your time.
clutching
try this 1st got a dealer and get an o/s/o primary spring (rx 1 mtn) then buy the sillver secounday spring. i allso would install a 5/16 lock washer on the secounday studs under the hlex. if you have the clutch tools try getting the belt side clerance down to about ,015-.020 tho .this is a low buck set up that work,s not to bad. note that your sled has the 15mm rollers all ready in the clutch. ;)!
