Dooer700
Hi.. I'm sure this has been covered before but I haven't had much luck in my search. My 08 Nytro rtx is blowing the fan fuse. Is there any common problem areas I should look? The harness by the clutch was caught and tied up before any damage was done. Anything that could save me some time would be appreciated! Thank you!
AttakDog
Just got done spending 2 hours troubleshooting mine, blew fuses at the end of the year. I just put a switch from the battery to the fan to finish the season last year. Tore everything down, checked the fan load=8.9 amps draw at start, 3.3 running. Fan is good. Swapped relays-good. Checked thermo sensor-good. Finally found a new rub spot, right against the left frame rail right by the fan wire plug in. The blue wire is the hot lead for the fan, check it for short to ground. Mine was rubbed just barely through and shorting there. I cut it back, re soldered it and wrapped it and put a thin piece of rubber there to stop the rub. Good Luck!
