Mine turns off when the sled is turned off.
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
- 2017 sidewinder ltx dx
2018 snoscoot
robertbubba2 said:212 is boiling temp some car the fans do not come on till 230 woul be nice to have a temp gauge
212 is boiling in ambient conditions. When under pressure the boiling point rises so temperatures can exceed 212 and not be boiling. If you crack the rad cap it then boils because it is no longer under pressure.
02xtreme
Does anyone know where the fan relay is? Is it one of the 4 relays located where the fuel pump relay is? If so how do I identify which one it is?
I tested the fan with 12v and it works fine, very quiet BTW.
How would I test the fan relay? Put 12v to it and listen for a click?
Snowmobileaddict
02xtreme said:Does anyone know where the fan relay is? Is it one of the 4 relays located where the fuel pump relay is? If so how do I identify which one it is?
Read my post in this link. It's the second post down and will tell you how to test your fan relay. And if you didn't already know on a wiring diagram "L" means a blue wire.
http://www.ty4stroke.com/viewtopic.php? ... ight=relay
02xtreme
Cool, thanks.
