livinloud
hi guys i am having a little dilema installing my mono skid into my proaction rx1. here is what i am confused with when i place my new apex tunnel bracket into my rx1 and line up the 5 existing rivet hole the ones that are alrerady predrilled which is supposed to make this swap so easy. my problem is that now that my distance between the rear hole and front hole is 21inches instead of 20.5inches does this matter?
jrd699
Send a PM to "viperguy" his name is Eric, and is an awsome guy to help you out..He can even send you a template for all holes to be drilled. I am doing mine soon and have his template, should make the job alot easier!! BTW what other parts did you have to order to make the skid work? and post some pics I wanna see what I'm in for!!!
