jsenske
- Sep 16, 2012
My oil pump didn't prime right away and it shut down after running 5-10seconds due to code 30. This happened until I figured out oil pump was not priming. All is good now but I was wondering what the chances of engine damage is.
You ran it 5-10 seconds?? You will be fine.
thor452
Because I can
- Jan 5, 2010
- Shawano,WI 54166
welcome to the site please post your location in your profile it is a site rule. 5-10 sec run with no oil pumping should have no chance of harm not long enough to build up sufficient heat to melt anything now that it is pumping fire it up let it iddle 10 mins or so till the foot rails get good and warm and listen to her. If there is a problem it will show up.
2nd thor and sleddog. As long as you were running it at idle you shouldn't have any issues.
I had this happen... you are good.
