Help
dirk_03
Lake Crystal, MN
Almost ready to finish up my turbo vector and I can't find my exhaust gasket. I am talking about the one that would go between the turbo and header. What are some alternatives that could be used temporary? Both flanges are very close to flat. I surfaced the header flanges on a manifold surfacer and the turbo I am sure is pretty good. So I don't need to seal up big imperfections.
1. Copper RTV? Will it handle the heat?
2. Copper Sheet? Where to get it?
3. aluminum annealed? Will this handle the heat?
I just want to be able to run it thie week to get it tuned and get a few miles on it.
I have seen YamaBond 6B used in place of a turbo flange gasket. This is what I have to use on the discharge flange as well (can't find a gasket).
Turbo gasket
I’m running a Alpine front mount GT2860 on my apex and I’m not running a gasket as I found the stainless bolts kept breaking do to expansion and contraction. And It’s been working great since. Good luck.
Re: Turbo gasket
Thanks Pat,
This is good to know. If anyone else doing this? Maybe with just a coating of ultra copper rtv or really thin copper sheet metal gasket?
I used permatex ultra copper on mine, never had a leak with good flat contact surfaces.
I thought yammabond wasnt designed for high heat and was somewhat semi-drying?
Ultra Copper RTV
Will probally try this. What is the best way to apply it. Make a bead, tighten bolts slightly and then let it dry and then tighten, Or make a bead and tighten while still wet?
The black 6B doesn't burn, tried it with a torch. Always had used that to seal 2-stroke pipe joints...
I now use it on the apex donuts and also gasket between the headers and cylinder head too.
I made mine out of copper sheet and don't use any sealer. It work fine. Ken...
Well I put the turbo on the header last night and used ultra copper. I think it seems like it will work well.
So onto the next question. I was only able to get lock washers on two of the four bolts. Should i be worried about this and try to get this changed. This is a custom built header and has very little room to get in and tighten bolts let alone getting a lock washer on two of them.
What are guys using?
