double a ron
I had to weld up a spot on my muffler that had cracked. After welding I installed the muffler, started the sled, put my hand over the muffler breifly to see if there were any leaks. The engine coughed a couple times due to exhaust backing up, took my hand off, sled was still running, turned it off.
But now it wont' start. Won't even fire. Did I damage something, could this have fouled up the plugs bad enough to not even fire?
Any thoughts?
Just cranks and cranks. no codes.
Any thoughts?
yukon yamaha
- Jan 30, 2008
- WHITEHORSE, YUKON CANADA
- 2008 nytro custom! 2014 viper custom
If it backfired maybe it is a fouled plug?
Usually the motor will stumble and backfire if you foul a plug.If it won't fire you may have fouled more then one plug.I would try that first.
sofunkingcool
Prob. a plug. But did you disconnect the battery when you were welding? You can fry everything if your not careful.
double a ron
The muffler was removed.^
It was the plugs. I haven't fouled any plugs in a 4 stroke yet. Used to my old 2-stroke, you could at least get it to fire and choke a bit, but I had nothing, not a single fire so I thought it was something else.
3 new plugs and away we go.
Thanks....a
Thanks....a
billymx815
- Nov 17, 2009
- S. Berwick, Maine
- SXV Venom, RTX Nytro, SR Viper RTX SE
- Maine
AWESOME that its fixed and not anything major. Happy trails to you
Daranello
Suspended
Better Q. How, why and where was the crack?
2008FxNytro
- Oct 7, 2009
- Upstate, NY
- www.mpminc.net
Another question. was the sled warmed up when you put your hand over the muffler? (red light on the dash off).
