Here's almost a pound of rotating weight mass easily removed
Frostbite
Eastern Washington- Cheney
If you are using an external belt height adjuster you can save yourself about 10-12 oz. of rotating mass from your secondary clatch. The three screws used to adjust your belt height are removed and also:
THE ZINC PLATED STEEL RING THE SCREWS CAME IN CONTACT WITH ON THE OUTSIDE SHEAVE ALONG WITH THREE LARGE SCREWS USED TO HOLD IT DOWN CAN BE REMOVED.
I removed mine today and thought I'd pass this on to anyone who may be using an external belt height adjsuter. Happy New Year. PB
