Has Yamaha corrected the angle between high and low beam for 2010 Apex and does the Vector have the same issue?
Several have tried to modify the High beam search light but have not read about any real success. I lowered my high beam to use as low beam and low beam lights up my skis. NOT A FIX.
I just did the bulb spacing thing to my Attak, went out and tested it last night. Helped a ton. Reduced the beam spread by quite a bit.
Yamaha needs to look at what Cat does.. now that's a nice setup for adjusting the headlights.
I guess no new information on this or 2010's
SharkAttak
RunninRX1 said:I just did the bulb spacing thing to my Attak, went out and tested it last night. Helped a ton. Reduced the beam spread by quite a bit.
what's the bulb spacing thing?
