SledWrecker
I just installed a 6000k bi-xenon HID kit today in my 08' MTX. I've almost got it wrapped up but I had a couple quick questions about the final install.
1. Anyone able to use the rubber boots that go around the stock H4 bulbs with the HID bulbs? If not do I just leave them off the sled?
2. I saw on another forum a guy modified the metal housing around the bulb. Why would you do this and does it help with output and light pattern? Picture attached at bottom
3. I noticed that sometimes my HID's wont shut off when I turn off the sled. I have 12v+ going to the starter relay and the grounds to the steering post mount. Everything is wired in exactly as it should be and hi/low function works as expected. If I turn the sled on and shut it off right away the lights will stay on. If I start it and let it run for atleast 30 seconds then shut it off the lights turn off. Possible stuck relay???
4. Any other advice with HIDs?
