high a/f on my nypex.
nytro-king
norway
cant seem to find the problem on my tnypex the af is high on idle .runs fine the first second after starting the engine .then it starts dropping down.11-12,3 . have disconected the mcx intercooler. and check the tps,
any tips people.
Did you just install low comp pistons or a head shim? If so check your work - you might have skipped a tooth on cam sprockets. If you have not done any engine work and bought the engine used - do a leak down test to rule out valve issues etc.
What you're saying... it starts to run rich after a few seconds of idle?
Will the sled run forward at all?
More details and we will be able to healp you out. Or did you fix the problem?
thats right. it runs on high af all the way. have new plugs and check't the fuel pressure. 42psi. shouldtn it have 36psi?.
AFR guideline:
Idle speed = 14.0-14.7
Take off = 13.5
0 lbs boost = 13.0
5 lbs boost = 12.5
10 lbs and up = 11.8-12.0
Does your sled move forward, will it run?
