BigAusti
- Dec 6, 2011
Picking up a new leftover nytro RTX this weekend hopefully. First thing I'm going to do is change the exhaust. Which one do you guys prefer? Which one is louder? And which one shows better HP gains? I'll be getting the full exhaust not just a slip on. Thanks for the input.:
Hindle gives the most hp is a plug n play solution. I believe it around 15 hp with a silencer. No modifications to the plastics necessary. It looks stock. It is installed in less than an hour. I just installed one myself a few weeks ago. It sounds great and isn't that loud at all. You can't go wrong here. I did a lot of reading before I pulled the trigger and not a bad thing out there on the Hindle setup. I can't speak for Excell but I'm sure that is a nice setup as well. I think there setup does require a change to the rear plastics.
