vsmpowered
- Feb 16, 2009
- Rochester , NY
- Nytro xtx Viper ltx se
so how the shocks worked out for you? looking into them need some feedback
marpolsdofer
phaze5 said:lets see some race vid dam it
I hade on but I lost it, but I have some posted from when JP used them.
marpolsdofer
I plan on running the full custom axis if I can find the money next year for them. I will be adding the exlink sytem to the front and also talked to CA to see if I wanted to get the hole shot sytem as well and make them work together.
yam177
- Aug 14, 2008
- Shoreview MN
- www.jbeurotech.com
vsmpowered said:so how the shocks worked out for you? looking into them need some feedback
Shocks worked real well first set of springs was to soft and caused the front to bottom and roll to much in the coroners. We got some stiffer spring son in Muni and it worked really well.
They took the biggest hit and realy made the sled perform well. I am realy happy with them and having Compresion High/Low rebound realy helps to dial in the suspension for the conditions.
The Fox shocks I had were also great but lack some more tuning when the conditions changed from course to course and as the day wore on.
yam177
- Aug 14, 2008
- Shoreview MN
Cross link and Hole shock stuff is not realy need3ed plus there is just not as much adjustment in an air shock. I am not as big a fan or the Air shocks yet The evols are nice But i still perfer tuning with a coil shock
marpolsdofer
I did not say I was getting the airshocks, everthing works for the sping shocks as weel.
HSS would just be for screwing around with (all it does is elimates you rebound on the front shocks). The cross link provides anot-roll without having to use a stiffer spring, so now you can. The plush ride stsyem would allow for lower ride without messing up and shocks setting.
http://www.customaxisshocks.com/ATV-Upgrades.php
- 8K
