jeremiah J butler
- Mar 11, 2018
- Ny
- 2009 fx nytro
Has anyone ever had a primary clutch wear a hole through the outer surface. 2009 nytro with 5500 miles. Is this common or another problem?
grizztracks
TY Advertiser
- Feb 24, 2005
- Scio, NY
I've never seen that before. You must of spent most of those 5500 miles at wide open throttle to wear out the top of the primary.
SaskAttack
- Jan 4, 2006
- Corning,SK.
- 17 Sidewinder XTX-SE
- Corning, SK. Canada
Never seen that before either, can you get us a better pic?
jeremiah J butler
- Mar 11, 2018
- Ny
- 2009 fx nytro
I will take one todayNever seen that before either, can you get us a better pic?
Michigandir
- Nov 28, 2014
- Michigan
- 2013 Yamaha nytro rtx
Are you sure your running the correct belt? Grizz is right. A hole up there would be wide open throttle all the time.
Pmtg04
- Jan 16, 2018
- Minnesota
- 2008 Nytro RTX
Did it actually drive/accelerate/backshift?
Stuck in overdrive from a failed spring in secondary?
Or something besides the belt rubbing on primary?
The opposing clutch face looks straight or burned/damaged/grooved?
Had the sled since new?
herndonp
- Nov 28, 2012
- Freedom,NH
- 2012 Yamaha Nytro XTX
Very bizaare. Never seen anything like that. I wonder if it was a bad casting from the get go.
Pete
Pete
