McDoug
I have a 04 warrior, will the springs help my performance or was it just 03 rx1's
black john
spring,s
these will help in all rx 1,s
Bob Miller
- Apr 19, 2003
- New Milford CT
- Present Sled: 2011 Yamaha Apex 128
I have them in my 04 Warrior
coreysask
- Jan 6, 2006
- Balgonie, Saskatchewan
- corey.cabler.com
What do the springs do?
Please please don't say push something back!
tmk50
The springs allow the slides to open all the way. The stock springs will not allow the carb slides to open all the way at altitude since the carbs are vaccuum assisted (need atmospheric pressure to work). Higher elevations require less 'spring'.
VForce_NS
this might be a dumb question too but if ya just got the stock air box and ya put the springs in will ya get better throttle response than the stock springs
BlgsRX-1mtn
- Apr 16, 2003
- Billings, MT
- '03 RX-1 Mountain LE
VForce_NS said:this might be a dumb question too but if ya just got the stock air box and ya put the springs in will ya get better throttle response than the stock springs
Yes you will if your above sea level. I had the red springs in my '03 RX-1 and saw better throttle response along with 200 more RPM without touching the clutches (this was @ 4700' elevation).
Jim
VForce_NS
the highest i would ever be above sea level would be like 2000 feet but most of the time it will be like probably 1000. but i know they will make a difference if ya can get the slides to pull up quicker. also i see at royal distributing they have the kn filters, and the 165 main jets, carb springs, pre filters what else do i really need other than that to make up like an ecp kit. it all comes seperate instead of a package thing i guess.
Jack_Shaft
Screw Royal man, just buy the real thing. Freddie is great to deal with and there are used ECP kits in the classifieds section all the time.
I am at sea level and the softer springs definitely allow for quicker throttle response.
Bob Miller
- Apr 19, 2003
- New Milford CT
McDoug said:I have a 04 warrior, will the springs help my performance or was it just 03 rx1's
Off their website:
Mikuni CV Carb Slide Springs for RX-1 Snowmobile
We have found some "easy" horsepower in these slide springs, specifically designed for three altitude ranges and inlets (stock or modified air box or carb filters) for the Yamaha RX-1 snowmobile (see table below). Improved throttle response and up to a 1000 RPM increase results from the use of these springs. A set of four springs come in a convenient carrying tube . For Vector applications, please call.
SUPERTUNER
- Aug 16, 2003
- Waterbury, Connecticut
- www.easterncycleperf.com
Thanks Jack_Shaft. I have silver, green and blue CV slide springs in stock.
Freddie
PH. (203)756-7019
Freddie
PH. (203)756-7019
