Homemade Screen kit?
tapp1
South Deerfield, MA
Any idea what type of screen material I should use if I want to to drill some holes in the side panels and dash? Anything that would be availabile at a Home Depot type of place?
Just curious.
I used the pet screen to cover up the vent in front of the oil tank. I drilled small holes around the factory vent, then used zip ties to hold the screen in place. Basically stitched it on. Worked good, probably stronger than glue but not as clean looking.
