johnelway
anybody as put some universal screen circle or square from frogskinz to vent the clutch
In the front the side panel or on the side?
some pics?
I don't want to put a whole kit cause i already have all hole covered with screen. Just need to put some air into my clutch and not snow.
some pics?
Kirkdking
Do you have a problem with her overheating or melting the belt???
I got all my vents closed off and I don't have any problems at all...
johnelway
yes little bit of overheat on my clutch when i do some powder. seems the heat can't get out enough.
i will drill some hole in my clutch guard this week and if it's not enough put some vent in the front and side.
FX NYTRO XTX 144
- Mar 5, 2013
- Trenary/ muskegon, mi
- FX Nytro XTX 144
I was blowing belts like crazy on my xtx.. Every 300 miles.. So i bought the oval 2 by 4 inch vents from frog skinz and put them on the clutch side panel and lower panel in the middle of the clutches.. I havent blow a belt sense.. 500 miles with no problems..
johnelway
FX NYTRO XTX 144 said:I was blowing belts like crazy on my xtx.. Every 300 miles.. So i bought the oval 2 by 4 inch vents from frog skinz and put them on the clutch side panel and lower panel in the middle of the clutches.. I havent blow a belt sense.. 500 miles with no problems..
can you post some pics? or send me by email johnelway2003@gmail.com
any problem in the powder?
FX NYTRO XTX 144
- Mar 5, 2013
- FX Nytro XTX 144
No problems in powder. Just once and a while wipe the vents off.. Ill send you pics of them tomorrow.. The sled is in the trailer and im on my way home from the U.P
johnelway
FX NYTRO XTX 144 said:No problems in powder. Just once and a while wipe the vents off.. Ill send you pics of them tomorrow.. The sled is in the trailer and im on my way home from the U.P
good thanks.
Will wait for the email.
