Had my primary cut for overdrive last month. Checked the offset with materials I had available. It was bang on 15mm.
Went for a 30 mile easy run to break in the belt. When I got back I checked the clutches. Secondary was warm as it should have been. The moving sheave of the primary was the same temp and the fixed sheave was quite a bit hotter.
Do I need to offset the secondary some more??
